100 Amp, 6/12V Battery Load Tester
Price
$20 USD
Ratings
Description
Fast and easy to use, this battery load tester checks your vehicle's charging system under working conditions. This load tester takes the guesswork out of electrical diagnosis, making it easy to pinpoint charging system failures. Test complete charging system including alternator, regulator, and battery. Also tests starter motor for excessive draw. For use with 6 volt or 12 volt systems Color-coded voltage meter for easy reading Heavy duty steel case with enamel finish Vinyl dipped steel clamps with copper plated jaws Heavy duty CCA wire
Forum Comments
Purchase a battery tester like this: 100A 6/12v Battery Load Tester
This is something that any at home, decent mechanic should have. [link] |||61747&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=Cj0KCQiAw_H-BRD-ARIsALQE_2O3fNUTy7oCQfRCnWi9wfvEJ_cH4_q7n96Z2fb9oZdFUigvCC9te_UaAhSXEALw_wcB
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
