After searching through many pages on aliexpress for the 6 pin connector that will work for the BMS harness, I found it.
The part number 7282-2764-30 did not come up with search results for some reason, so I had to search through many pages of "6 pin connector".
Here are the two listing for the connectors you will need: Of course you can order these parts elsewhere if you can find them locally, I wasn't able to find them in the USA.
You need 3 of the one connector and 3 of the other, make sure to check what connectors your pack harness is using and what you need for a 6 LTO pack. Make sure you get proper male or female in the link. This will make your connections to the BMS nice and neat.
If you order both from the same place I believe you can get all 6 connectors with shipping for $18 Dollars + Tax.
www.aliexpress.com
www.aliexpress.com
1.88US $ |1set 6 Pin 0.6 Sealed Waterproof Wiringcase Connector Socket Car Auto Connector Plug 7282-2764-30 7283-2764-30 For Nissan Toyota - Connectors - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
1.28US $ |1 set 8 pin car waterproof auto connector 7283 2148 30 7282 2148 30 Electrical Car Wire Plug Housing for Nissan Toyota Honda|Connectors| - AliExpress
