ACDelco Gold B24R 24 Month Warranty Hybrid Vehicle AGM BCI Group 51 Battery
Price
$290 USD
Ratings
Description
Note: Refer a user manual before use Durable design protects against the worst enemy of a truck battery – road vibration (compared to standard flooded batteries) Calcium alloy is optimized to produce a fine grain, corrosion-resistant grid, maximize cycle life and minimizes water consumption for battery durability Fully charged ACDelco Batteries (OCV is >12.5) should be stored in an upright position at temperatures between 32°F and 70°F. When a battery is stored, a very slow chemical reaction takes place between the plate materials and the electrolyte, causing a slow discharge. This reaction, called a self-discharge, occurs more rapidly at higher temperatures. Therefore, it is not recommended to store next to a furnace or other heat source. If an ACDelco Battery is completely discharged, the electrolyte will freeze when stored below 30°F. To prevent electrolyte freezing and battery damage, do not store ACDelco Batteries below 30°F if their OCV is less than 12.5 volts. Check battery every 2 months and maintain a voltage of 12.4 volts or higher
Forum Comments
NoD~ mentioned in Gen1 12 V Battery Recommendation
I use this, but note that it does not have standard terminals and needs adapters: ACDelco ACDB24R Advantage AGM Automotive BCI Group 51 Battery:Amazon:Automotive
NoD~ mentioned in Adding an alternator
1 - I went all LED lighting (including headlights!) so I think the 50A max should be fine. I do have a subwoofer with a high efficiency amp, but I don't "bump it", just use it ... more
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
