ARES 70016 - Damaged Bolt and Stud Extractor Tool - Grips and Removes 1/4-Inch to 1/2-Inch Studs - Ideal for Broken, Rounded Off, Painted Over, and Rusted Tight Bolts
Price
$22 USD
Ratings
Description
- ABOUT THE TOOL: This damaged bolt and stud extractor tool is 3/8-inch drive and can be used with manual or pneumatic impact wrenches and ratchets. The hexagonal flat can also be used with flat wrenches, adjustable wrenches, sockets, and locking pliers. Manufactured with high-grade Heat-Treated Alloy Steel for maximum durability, this tool also features a chrome finish for additional rust protection. - MULTIPLE USES: This bolt extractor will save hours of frustration on broken exhaust manifolds, oil filler plugs, rounded starter bolts, low grade bolts left in saltwater, painted-over bolts, rusted tight bolts and more. - TRADITIONAL BOLT EXTRACTORS: Traditional bolt extractors force the user to guess which size the damaged stud is. They have a tendency to strip the screw even more and shave metal off without budging the screw, leaving you worse off than when you started. The design of this bolt extractor allows you to clamp down on the damaged stud, eliminating the guess work. - RELIABLE | EFFECTIVE | EFFICIENT: Users trust ARES to be quality tools. You are backed by our Performance Assurance Limited Lifetime Warranty. If you have any issues with your ARES Damaged Bolt and Stud Extractor Tool, simply contact customer service for troubleshooting help, parts, replacement, or refund. Need a manual? Download it for free on our website! - ASPCA BUSINESS AMBASSADOR: We are proud to be part of the ASPCA Business Ambassador Program. If you have a pet, you realize they are more than a pet, they are part of the family. With your support, we’re proud to help this great organization.
Forum Comments
Ecky mentioned in Will a CVT upper cat work in a MT?
The studs unscrew from the head pretty easily. Even if they're pretty destroyed, you can cut the nut off and get them with a bolt extractor like one of these: [link] or [link] I'd probably liberally cover the studs with anti-seize and switch the nuts out for stainless. Either that, or use a stainless bolt instead of the ... more
insightbrewery mentioned in Ground Strap Bolt Busted
Our cars have aluminum chassis, yeah? Lol, last time I had to get it towed, the driver kept trying to stick his magnetic brake lights on it before I noticed and told him it was ... more
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
