Auxbeam H4 LED Bulbs, H4 9003 HB2 P43T Led Light Bulbs 60W 12000lm H4 Led Conversion Kits LED Chips F-16 Series
Price
$55 USD
Ratings
Description
【300% ULTRA-HIGH BRIGHTNESS】F-16 series H4 9003 led light bulbs, use automotive upgrade led chips, light output with 60W power and 12000LM per set, providing better visibility up to 300% light and 6000K white for a wider, farther and clearer road situation. 【SUPER BRIGHT FOR SAFE DRIVING】H4 9003 light bulb with 360° illumination, no blind zone. Engineering beam pattern throw super bright light on the road evenly at appropriate angle without dark spots/foggy light, not dazzle on-coming traffics. IP68 waterproof designed, rainproof housing and fan, works perfectly in extreme weather conditions. 【EMC & EXTERNAL DRIVER DESIGN】Use advanced EMC tech without electromagnetic interference, completely isolate the interference of car audio and driving computer, escort for save driving; External control driver helps get optimal heat protection and performance. Built-in constant current CPU, instant full brightness without start-up relay. 【MAXIMUM HEAT DISSIPATION】H4 9003 LED light conversion with two-way heat dissipation channel. All-in-one heat conduction+high speed mute fan (12000R/Min) system, high air flow for faster cooling rate ensures maximum heat dissipation and prolongs lifespan over 30,000hrs. 【Fits for 99% of Vehicles】This H4 9003 led light bulb work with 99% of vehicle's computer system without error, while some sensitive models may require additional CAN bus decoder to be installed. Before purchase please refer to owner's manual or original bulb’s part number and size of your car to make sure it fits. (refer to size image)
Forum Comments
Atheos mentioned in LEDs headlight bulbs
I installed these a couple of months ago, and so far they are great. [link] went with LED in the turn signals, markers, inside lights and I really like it.
AP1ZE1 mentioned in LEDs headlight bulbs
What LED brand did you buy for the tail light/brake lights? Do you still have the link to Amazon?
I bought the same and installed them today on the front. Did you have to leave the big rubber donuts out that seal the back of the headlights like Sam and Boojum? Still trying ... more
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
