Baomain Heatsink Shape Bridge Rectifier SQL 100A 1200V 3 Phase Diode Metal Case
Price
$12 USD
Ratings
Description
name : Bridge Rectifier; Output Current: 100A Repetitive Peak Reverse Voltage : 1200V; max. Working temp. : 150C; Pin : 5 Fixing Holes Diameter : 5 mm / 0. 19"; Fixing Holes Spacing : 52 mm / 2" main body Size : 98 x 59 x 29 mm / 3. 86" x 2. 3" x 1. 1" (L*W*T); Overall height : 53 mm / 2. 09 inch Net weight : 253g; Package Content : 1 x bridge rectifier
Forum Comments
To answer your third question, it's just the 3 orange wires to the 3 leads on the 3-phase rectifier in any order, then two leads from the two on the rectifier to the input on the ... more
Thanks a ton for this info, mpg numbers dude! It will make things a lot easier. :D
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
