BATIGE Dual Ports Square USB 3.0 Panel Flush Mount Extension Cable with Buckle for Car Truck Boat Motorcycle Dashboard-3ft
Price
$12 USD
Ratings
Description
This batige square USB 3.0 panel flush mount cable design for car,boat and motorcycle Dual USB 3.0 panel cable is made of premium material, it is a nice heavy duty cables. You can use this USB 3.0 dash mount cable as an USB extension for not only a car,boat,motorcycle dashboard, but also a studio set up that you have. The square USB 3.0 car mount flush cable is thick and durable, in normal cases,use an existing hole or cut a hole on your dashboard and clip in the socket to flush mount it to your vehicle's,boat’s and motors. Ideal for extend and accomplish the data transfer in your car, boat, motorcycle, support very easy access to your accessory inputs. And USB 3.0 backward-compatible USB 2.0. This square USB 3.0 panel dashboard cable is Male to Female,with buckle,very easy to install. 3ft length.
Forum Comments
jrronimo mentioned in 2010
Yep! I have a 2010 Insight and I replaced the stock radio with a Sony XAV-AX5000. I bought this Dash kit, which came with the wiring and antenna harness: Amazon.com The dash kit feels a little cheap if I'm honest, but it did the job. I cut a hole in the dash mount and used this USB header: [link] It doesn't look amazing, ... more
savi18 mentioned in 2010
Hi jrronimo, thanks for the reply, that radio looks good, dash kit they are out of stock so will look on Ali-Express for one, did you manage to retain your reversing camera and was it all plug and play, Cheers Derek ps: Think that dash kit is for left hand drive where mine is RHD.
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
