Battery Tender Engine Start Battery: Lithium Motorcycle Battery with Smart Battery Management System (BMS) - 12V 2.5 AH 150 CCA Lightweight Scooter and Motorcycle Starting Batteries - BTL09A150CW
Price
$118 USD
Ratings
Description
HIGH PERFORMANCE: Reliably start your vehicle and turn on the lights, radio and other motorcycle electronics in all temperatures and climates with our high powered LiFePO4 engine start 12v battery GET SMART: A built in protection circuit board prevents overcharging, discharging and overdrain; when overcharge or over discharge is detected, the BMS shuts off the battery to avert permanent damage SAFETY FIRST: Engineered to be safer, our battery is equipped with a protection circuit board, water resistant casing, and fire retardant coating that supports high current flow for thermal protection LIGHTWEIGHT, INCREASED EFFICIENCY: Environmentally friendly and weighing just 1.76 lbs, our economically sized battery increases fuel efficiency and provides a higher capacity while lasting longer SPECS: Our 12v lithium battery measures 4.49 x 2.80 x 3.27" with a 2.5 aH battery capacity, 150 CCA and 32 watt hours, and includes an activation switch on the Quick Disconnect Cable to activate charging
Forum Comments
S Keith mentioned in What lithium 12v battery to buy
Lithium is a great solution as it doesn't give a shit if you store it at a lower state of charge. In fact, they last longer if you keep them off the top. [link]
Its accesory power not parasitic. So im thinking this battery any other recommendations? [link] Or maybe this is better value [link]
Forum Reviews
There are no reviews.
Write a Review
Leave a review by signing in.
