What prompted you to take it to a dealer? Running bad? CEL light?
What was the CEL code? Sometimes you can get a false code, code should be duplicated by the dealer before replacing.
I don't think I've heard of a sensor "Failing completely" engine would probably either "Die" or run in limp mode...?
Did you buy the car from a Honda dealer? How long did you own the vehicle. Even on used vehicles dealers normally have a limited warranty.
Price of o2 sensor #1 in Calif. is 250 from dealer......Labor and testing 1 hour labor...............Assuming they did that.
Need more details.
Need more details.
I bought the car used in December 05 with 32k miles
BP owned it for testing various fuels for improving air quality MPGs and emissions.
It spend most of it's life indoors on rollers and on a test track.
After buying it within a month I had a CEL that went away in a few days.
Another 3k miles I got another CEL, went away.
Another 1k miles CEL on same stretch of road, same type of trip.
Another 1k miles another CEL.
I have noticed some low end chugging and bogging/surging.
The CEL was not activated by this.
After the last CEL I brought it in to have the codes pulled, they said all the codes were for O2 Sensor 1 malfunction. I did not get the code number, however I believe them
MY O2 sensor failed around 50k miles. What happened was the heating element on it failed. SO when the exhaust temp reached a hot enough temperature for the sensor to function properly, I could clear a code and drive a very long time with no issues.
If you still need help on this I can email you some of the diagnostics that I received.
