I have a 2010 Insight and the 12V battery stops charging shortly after the engine starts. I start out with a fully charged battery (grid charged) and the car runs fine. After several trips it finally won't start and has to be jumped.
I monitored the voltage at the cigarette plug and when I start it, the voltage is around 14.2 or thereabouts and after a few minutes it has dropped to about 12.2 or lower. When it gets much lower (around 11 volts) I know it won't start. I charge the 12V battery up and it goes for another couple of weeks of occasional use until the battery is dead again. The voltage readings always start showing 14+ volts when running, and it tapers down to the low 12 volts. Battery has been load checked twice and its OK.
Any ideas?
What is the age of that 12 volt battery?
This battery is about 18 months. I replaced the prior battery because I thought it may have been the problem, but the same problem exists with the newer battery. I think I mentioned that I load tested it. I also checked its abiility to take a charge and at what voltage (with a variable power supply) and it checks out.
Thanks
I can't say much about the problem with the voltage drop after engine start on the Gen 2.
About the load test, though... I recently took a weak battery to Walmart for load testing. They claimed it was fine even though it would not last long with the engine off. I asked them to do the extended load test and the printout claimed it was OK, but the automated tester rated it as having only 11 AH of capacity. For comparison, a typical small consumer UPS uses a 7 AH battery; you could fit quite a few of these in the space of an Insight 12V battery. In other words, it might have had enough oomph to start a car once, but not enough to keep the car running for much time afterward. Check the printout from the test and see if it lists a tested capacity in amp-hours. Not that it's going to solve the problem of charging stopping after a short amount of time.
Does the battery voltage stay higher/ok if you turn the headlights on?
You could have a faulty 12V load sensor in the fuse box..
But I suspect bad 12v battery at the moment.
