I just bought a 2002 Insight with 17,000 miles on it. Having just spent over four years living on a boat off-grid, I've become very attuned to 12v battery happiness.
Inasmuch as I'm an Insight newbie and am experiencing some fairly significant IMA battery level variations (perhaps normal, as I live in the hills), I thought I'd first monitor the 12v battery voltage level just to get an idea of its normal behavior. So we went for a pleasant 80-mile drive in the country (av'g. 64.3mpg - I'm still learning)...
I simply plugged in a digital voltmeter into the accessory socket and expected to see a fairly steady float voltage somewhere around 13.5v. I was shocked by the results: this voltage VARIES RAPIDLY and ranges from 13.6v down to 9.8v, often sitting in the 10v range for minutes at a time. I couldn't correlate this to either IMA level or IMA charging/discharging status nor to engine revs nor lights/accessories. Made me suspect that I have an intermittent shorted cell or two in the 12v battery. After letting the car sit overnight in the garage, I measured 12.37v across the 12v battery without turning anything on. Perhaps a little low, and maybe time to search for a battery replacement...
Our Insight came with a factory-original "Maintenance Free" wet-cell semi-sealed battery which I presume contains plates which are lead-calcium. These batteries are optimally charged at14.8v and prefer float voltages of 13.1v-13.4v (a little lower than the 13.6v I measured).
(deleted long-winded technical discussion comparing all sorts of battery types)
The favored replacement for our Insight's stock battery is the Hawker Odyssey which is an AGM VRLA. The OdysseyFactory.com website recommends charging at 14.4v-14.7v and floating at 13.6v-13.8v. Not a problem, and should be quite compatible with whatever the voltage regulation is from our DC-DC Converter (i.e., if it works with the MaintenanceFree battery then it's just fine for the AGM, presuming it's got a current limiter which will accommodate the AGM's lower internal impedance).
So far so good, and I'm about to place an order for the smaller (lighter) Odyssey PC545 , together with custom aluminum mounting bracket and terminal adapters. This smaller battery was selected since I live in a mild climate, we don't need deep-cycle capability (playing the stereo while parked for a few hours won't deplete it), and if we have to crank for more than five seconds using the starter, something else is wrong.
Before I do that, however, has anyone else monitored their 12v? If so, what are the voltage variations experienced?
Thanks in advance, and thanks to those who previously discussed and showed pictures of their replacement 12v batteries, and sorry for being so long-winded.
