@Hybrid ReVolt I put in an order for two, one for each Insight, but with a note to cancel the order if they don't have an automatic disconnect if someone leaves the dome or headlights on, or if the discharge current rating is not sufficient for an Gen 1 Insight starter motor to turn over a cold engine (I don't know the current draw of the Insight starter motor when cold, does anyone?)
It would be useful to know the max allowed charging voltage to keep the cells from being overcharged or one from running away (I'm pretty sure I can mod set the DCDC converter output to whatever is necessary, and it certainly can be disconnected with an external monitor to prevent exceeding the max allowed battery voltage) and it would be nice to know the cut-off low voltage as well. It does not look like there is a status output that we can leverage for an internal battery meter, but if there is one accessible inside the pack, I would be happy to look into it, assuming it can be disassembled. And of course, with the high and low voltage limits known it is easy to make a custom meter from one of the many Arduino-compatible boards that also have displays.
Thanks a TON for keeping us in mind and offering these to us, and reminding us that you still have them. I held off on these when you first announced them, thinking I could repurpose an LTO pack for this, but if these have the low voltage protection and can supply the max starting current, $100 is a terrific deal.
