Year
2000
-Color
Citrus
-Transmission (5spd/CVT)
5spd
-Current Mileage
207,000 mi
-Asking Price
$3000US
-Location
Lansing, MI
-High Voltage Battery Age/Condition
roughly 11-12 years, needs to be reset with moderate use, but does function okay under light use and in warmer conditions. Needs to be replaced or refurbished
-Transmission Condition
Excellent
-Engine or IMA Codes Showing
Yes, both. I can get that info later, but don't have the codes on hand.
-Interior Condition Summary
I took the seats completely apart and soaped/power washed the foam and covers, put them back together, and put seat covers over them directly afterwards, and removed and washed the entire carpet and interior panels about 5-6 years ago when I bought the car. I don't have pictures of the interior at the moment. With a detail it should look quite nice. missing the OEM floor mats so I made my own. replaced OEM door speakers with polk 6.5" and added one of these behind the drivers seat as well. The car has 5% window tint on all windows except the windshield, and the windshield has 50% tint. Alpine head unit. intermittent working backlight on left side of the instrument cluster. trip button has stopped functioning.
-Exterior Condition Summary
the pass. side was painted and a dent was repaired before I purchased the car. I was told it was backed into in their driveway at a low speed. paint is starting to fad a bit. the hood has damage and the Honda emblem is now gone. the antennae could stand to be replaced as its held together by tape at the moment. drivers window gasket is preventing the window from rolling up unless you help it. the car will come with several replacement parts that I purchased but haven't put on the car yet, including the drivers window seal, drivers front bumper aero (whats it called again, in front of the tire?) several gaskets, clips and hardware. comes with a brand new set of OEM bridgstone RE92 tires with the labels on them. the tires on the car are at the end of their life. Also, there is a custom made (obviously) receiver hitch on the car, that I mounted to the frame rails with a welded aluminum spacer in the frame to keep it from crushing. The air suspension was originally a prototype kit for an Acura RSX that I made to fit the car. Mini Cooper rear strut cartridges with custom made T-bolt mounts with spherical bearings. New shock mounts were made and welded to the trailing arm to fit these on the car. The air management is the AirLift V3 with 3/8" air lines. The air suspension does not and has not ever leaked and can be driven without the management system functioning. I used to be a prototype suspension engineer at AirLift Performance and that is why this one off kit exists. The valving needs a little tuning to feel proper on the road, but would be very well suited on a race track with an RSX engine swap.
84242
84243
84244
84245
Hi,
What is the paint on the roof and hood like? Are all under body panels still in place?
Not that I would want to switch it back to stock, but could the suspension be put back to stock if I had an old parts or a donor car?
Do you have interior pictures and of engine bay?
Thanks,
Jeff
Hi,
Thanks,
Jeff
the hood is not in perfect condition, and had some damage at some point before I found it. the paint is a bit faded on the hood and roof. some of the underbody panels are missing or were cut and zip tied or screwed to the body. the suspension could be put back to stock with spacers in the front, but the rear lower shock mounts are completely modified and won't be able to be returned to stock without reversing the modification. I do have the old suspension, but the rear shocks are blown. I don't have interior pics or engine bay pics on my computer but I could get some eventually. I am sick with the flu right now, and I won't be going outside in this cold unless I really need to.
