Just pulled out today. Engine was very healthy with 175k miles. Didn't burn oil, leak oil, smoke, knock or tick. Ran amazing. I want $300 for the long block not including coils, cat or wire harness. Engine was only pulled to do a swap.
5 speed manual trans, all gears worked great, first gear would grind during downshifts unless you were doing less then 10 mph. I have a new oem Honda input shaft bearing I'll include with the sale of the transmission. It was making noise till I changed the transmission fluid and then within a week or so it quieted down a lot.
Also have D.C.-D.C. Converter, cats, coils, wideband o2 sensor in good working order available.
Located in Salem Oregon about an hour south of Vancouver Washington
To reach me fastest text me 503 798 7181 -trevor
Price of transmission?
Bump. All parts are make offer. Located in Salem Oregon. I'd like to get this stuff out of my garage to clear up some room
Interested in engine. Sending PM
