1 - 12 of 12 Posts
No I have not purchased it. Maybe someone could chime in with what goes wrong with the CVT Transmissions and if the parts to fix it are in this kit.
Common problem is one of the big bearings starts making noise. And I can't imagine a proper rebuild without replacing the metal pulley which is over $600 alone.
If it ain't broke.....
Have we seen an actual failure of the variable pulleys? If so at what mileage and maintenance levels? I think there will be a demand for proper CVT rebuilds in the future.
Yeah, kinda. I'd just like to have a better understanding of what goes on in a CVT like we do the the 5-speeds. I thought you would have data on the MTBF on these pulleys since you brought it up.
The same guy who would replace CVT pulleys? ;)
If I wasn't clear when I said metal pulley I should have said metal pulley BELT. A gear is a solid piece of steel that, absent of abuse or lack of lubrication, should last a million miles. The belt is made of 100+ links joined together, with then, 100+ wear points.
Yep. That's a whole different deal. I would at least inspect it for visual wear and play in the pins.
But how many have we had break?
1 - 12 of 12 Posts
