I've been driving my '01 G1 5MT for 7 years, now at 230k miles. It was getting a little down at the heels however I decided to fix things including new brake and fuel lines, AC compressor, shifter cables, e-brake cables, rear brake backing plates & cylinders, front brake pads, valve cover gasket, both front ball joint/control arm assemblies, engine temp sensor, upper catalytic converter, brake pads, and replaced my worn out IMA battery with a newer battery that is performing well. Wow. I don't know if the car has ever performed better. No codes, perfect battery performance and I'm getting better mileage than I ever did, now averaging 67 + mpg. I was on the fence about spending $ thinking maybe the car was just too far gone however I am really pleased with the result and I encourage anyone sitting on the fence as to whether to fix up their G1's to go for it. FYI I also changed my regular oil from Mobil 1 synthetic to Royal Purple - I wonder if the Royal Purple may have contributed to the mpg increase?
I've owned my Insight for about five years now. I bought it with 138k and now it's got 176k and, as of January 2020, I drive about 500+ a week. I've recently noticed a MPG increase as well. I'm not really sure why. I'm averaging about 65-66 MPG. I did just adjust the valves. I think another aspect of it is learning how to drive these cars. There is a learning curve. When my wife drives the Insight the MPG is nowhere near as good. Maybe that's a factor with your's as well.
It very well could be that the cat was somewhat restricted or you may have had a dragging caliper.
These cars are in most likelihood never going to be remade so not wanting to invest in a tool that pays dividends is kind of a capitalist mentality.
New cars always are pushed as being improved, xyz reason, we have been brainwashed. I’ll keep mine forever even if I have to replace engine or kswap. Whatever. The aluminum body is lightweight and aero. Perfect car for mpg.
When my wife drives the car gets better mileage and returns home with an only-dreamed of SOC. I really need to ride with her and figure out what she does. Every Single Time!!! Drives me crazy. I got my first one in 2010 and have racked up lots of (apparently inefficient) Gen 1 Insight miles.
