1 - 7 of 7 Posts
Starting off in first gear the clutch grabs about an inch from the top. Every time it is a rough almost pitted release I don’t know if it’s the pressure plate release bearing or clutch. Or if it’s something else. Is there anyway to adjust the clutch
Nope. No adjustment.. They do do this especially when damp/worn.
Just fit a new OEM clutch pack..
It's like night and day... Old v new...
Do the gearbox input shaft bearing as well while it is out..
Chicago & Detroit
Should also put the tiniest bit of high temperature grease on the clutch spline
Is your IMA working? The clutch will chatter more if the IMA isn't helping it get moving.
1 - 7 of 7 Posts
