$1000 OBO, 2003, red,5spd,133k, Grass Lake, MI, original battery (still charges), trans is great (no grinding), no IMA or Engine codes, Interior has some wear (hole in drivers seat back). Exterior has some clear coat loss and fading. Small crack in windshield under wipper.Several brake lines were replaced 2 years ago and then the master cylinder failed (replacement in box). The line from the clutch cylinder failed and so must be started in gear and humped (replacement in box). 2 ½ year old Michelin tires with perhaps 10k on them (need rims cleaned as they lose pressure over time). Genesis 1 grid charger with discharger and extra 5spd trans that has grinding gears (from previous insight) and so would need rebuilding. There is a little undiagnosed thump in the engine, could be a problem or not? Sitting in my barn on jack stands. Will have to be trailered or towed. 2 sets of manuals Call me at 734 883-7010
