1 - 8 of 8 Posts
My old Civic wouldn't start despite my best efforts and knowledge (charging the battery, checking the plugs), and try several times to jump started. So we towed it to the Honda place and they ran diagnostics to no avail. See attached report!
Any idea what it can be and if I can fix it ? my other option is to junk it and cry. (say goodbye to her and to 2 sets of good tires and have to look for a replacement)
Font Material property Publication Newspaper Monochrome
Greatly appreciate any input, ideas, options, and leads
They got code U0110, but their notes do not reflect the troubleshooting steps in the service manual (pages 11-167 through 11-168 in the 2003-2004 Civic Hybrid service manual, 1st edition). Next, they are observing a blown fuse, but rather than diagnose it, they are going straight to replacing a computer. I don't understand this; as Peter pointed out, it could be something like fan drawing too much current. Or mice having eaten harness.
They do not positively identify which fuse is blowing. Which fuse (fuse number) is it and where is it located?
You can fix it. You will need a service manual, some tools, ideally a code reader capable of reading IMA codes, a place to work, and no hard deadline. You can buy the tools as you need them. The alternative is to find a good independent mechanic who is well respected (Yelp? + references) and enjoys puzzles, and pay them, keeping in mind that it may take hours just to troubleshoot and there may be several things that need to be fixed. Either is a far better option than junking, in my opinion.
Where are you located? I have a 2004 HCH. If you are really going to call the wrecker, then mine might want a twin.
2000 Silverstone G1- 200k miles
Took me a hot minute to find out I had a cut wire. It's not awfully complicated, just super time consuming. The service manual tells you step by step what to look for. Wish you the best.
1 - 8 of 8 Posts
