What do most Insight folks use, the Max Volts brand? They will not tell me the charge current spec!! WOW!! Are they the way to go?
I use a Maxx Volts charger. It works great and I haven't had any problems with it. They are also much cheaper than other chargers. They aren't as user-friendly as others, but as long as you know what you're doing it's fine. They do have fairly good customer support too. I just charge for 24 hours, then discharge to about 90v, then repeat. Hope this helps :)
...you attach this power supply to your IMA to charge it?
Yes.
And I assume if you do that you would be keeping a pretty close eye on the voltage in the battery?
Not any more than you'd do with any of the 'vendor' chargers. I do run my fan with the OBDIIC&C though. If you didn't have one of those you'd need an extra 12V supply to power the fan.
