1 - 1 of 1 Posts
Okay, so here's the deal: my passenger side tail light assembly is having issues. When I use the turn signal, the light doesn't work, and it clicks super fast. The brake light also doesn't work from what I've been told as well. I checked all the fuses, opened up both sides assemblies, swapped bulbs, but to no avail. The bulbs on the passenger side, all work on the driver's side. I read somewhere that you need to have all of them connected for them to work, but that's not true as I independently tested each one without the assembly being connected. I'm lost now. I suppose it could be the wiring, but how would one go about checking that? Any suggestions from anybody who's had a similar problem? Thanks in advance for your help!
1 - 1 of 1 Posts
