1 - 13 of 13 Posts
I need to trouble shoot the alarm system. Once I lock the car and set the alarm, the alarm system will go off at random times for no reason. At least three times it was a few minutes after I walked away. Once in the middle of the day when I had not driven it that day. And several other times that I know of. I thought it might be my key fob so I found the second one and it made no difference. Are there fuses? I may be a wiring problem?
Post in the Insight 2 forum below this one, you might get some intelligent answers about your model
Thread moved to 2nd Gen forum.
First off Stacy, is your 2010 Insight an EX? (does it gave a usb connection in the center console?) only EX Insights have the factory alarm. If it is in fact the stock one, my suggestion would be to check the little rubber covered buttons that activate the interior lights. Those are what signal the alarm that a door is open. In other Hondas there is also a switch for the hood. Any of these things can make the alarm go off.
If you have some aftermarket alarm put on a base or LX model or some "enhancement" add on it could be a lot of other things.
By the way, one does not have to do anything beyond locking the doors to set the stock alarm. The honk on the second press adds nothing except annoyance to the neighbors. That honk is for when you are walking away in a raking lot and cannot remember if you locked the car. The "alarm is set" indicator is the flashing red light by the speedometer. The one on the radio will blink regardless.
I have not tried this in the Insight, but in my other Honda, if I use the central lock on the Passanger side to lock up, the doors are locked but no alarm is set. That might be a work around for the short term.
The alarm system depends on your location.
In Europe the ES / HS models also have a factory alarm.
Did u get it sorted
is that all ES models? Or only certain batches? Bought a Honda Insight ES 2010, no alarm after locking the door and pushing the car. How do I check whether my model has or has not the alarm system please?
Hi everybody,i have honda insight ex 2010,somebody can explaine what is this item is it lock or security system?can it ocure not start vehicle?thanks
I think it’s a Japanese toll scanner or such
Saw something similar here somewhere
It’s a nap import? Not European spec?
mine got set off as I accidentally set it off whilst sitting inside the car
Must have locked it and tried to open the door( from the inside)
Es should have alarm
Definitely if it’s ES model it has an alarm
1 - 13 of 13 Posts
