1 - 8 of 8 Posts
2010 insight was running fine and then stalled out. Now it will not start. plugs have been changed. Will run on shots of ether, so fuel issue? Fuel pump is getting voltage and has pressure at outlet. I am new to Gen 2 insights and would appreciate ant help or ideas of what to look at next.
100k. Not sure on codes. Fuel is green. Not sure how that happened, but it is green like a crayon. Today I am going to pump out all of the gas and replace it with fresh.
Did you fill it with gas shortly before it stalled?
I don't think so. Stepdaughters car. The only explanation I can think of is sabotage. Dealer said it needed a fuel pump. I pulled the fuel line at the rail and cranked the motor. Fuel pump working.
Hmmm. Is Diesel green? Does it smell like Diesel?
it did not smell like diesel sam. I did solve the issue. removed fuel pump. cleaned tank out completely. added a can of seafoam and 5 gallons of fresh gas. it started up and ran rough for the 1st 5 minutes. now it runs great. guess it was just bad gas. had some paper towels soaked in the stuff and it would barely burn in the firepit. p.s. dealer wanted 1500 to replace plugs and fuel pump.
Wow. I'm glad it came out well! Thanks for the closure.
1 - 8 of 8 Posts
