1 - 1 of 1 Posts
Moderator
The first ever Subaru Hybrid.
AWD, 2.0 Boxer engine, CVT....AND COOL CITRUS COLOR TOO! How can you not love this car?
"With the XV Crosstrek Hybrid, Subaru re-engineered the chassis to handle the added weight of the battery system, improving handling, steering and ride. In addition to chassis changes, the XV Crosstrek Hybrid added extra sound insulation, a start/stop feature, revised HVAC, new gauge cluster, keyless start and numerous other changes. The Subaru XV Crosstrek Hybrid combines a 2.0-liter Subaru BOXER engine with a 13.4-hp electric
motor thatʼs integrated into the Lineartronic® Continuously Variable Transmission (CVT). A 100v, 13.5kw nickel-metal hydride battery is located under a revised rear floor area, and the engine uses an integrated starter/generator for the automatic start/stop feature. The compact hybrid system weighs just 209 lbs. and places the electric motor just behind the transmission and in front of the continuously variable transfer clutch. With the addition of all the new features, the XV Crosstrek Hybrid weighs approximately 300 lbs. more than the gasoline engine XV Crosstrek. Under light acceleration, the Subaru-engineered hybrid system uses the electric motor for initial vehicle acceleration and then starts the gasoline engine once underway. The electric motor can also provide motor assist for acceleration in parallel with the gasoline engine, and an EV mode will operate the vehicle in certain low-speed situations."
"Exclusive to the North American market, a new Active Grille Shutter system helps reduce air resistance. The air conditioning system uses a temperature and humidity sensor to optimize operation for reduced draw on engine power."
More Info: The 2014 XV Crosstrek Hybrid | Subaru of America
1 - 1 of 1 Posts
