It tore off after an oil change, going to do all oil changes myself now. Anyone know what the part number is as well as for the screws? Thank you!!
You could try the online parts source majestichonda.com. They probably sell the replacement parts and would have the part numbers:)
Aegean Blue 2020 Honda Insight EX
Honda does not make things easy to find...
In the attachment, items 25 and 27 are your mounting hardware. I thought the metal plate had a separate part number, but on this it is just the whole cover assembly as item 11. I will check again when I wake up as it might have been hidden in another diagram. Keep in mind if you do buy the whole cover {item 11} it should come with the screws.
Also, double check the numbers with the dealer as I only had access to the American parts list and a few, not many, are different for the Canadian version.
Side note, Gen3Insight is a far more active forum than this one for the, well, gen 3 Insight.
