I know that's right! They were slow loooooong before covid, though.Thanks to covid, I'm never in a hurry when ordering anything anymore...
Stupid Amazon has people wanting things yesterday!
Now 928 cycles. Isn't that like 3 years? It's basically one cycle per day right?Thanks to covid, I'm never in a hurry when ordering anything anymore...
I've been meaning to analyze the data from these first cells... been super busy these past few days, so haven't had a chance to even switch over to non-damaged ones.
Rough overview:
-EHW5 cell has QTY938 cycles on it and is still going strong.
-47 Ah FoMoCo cell has QTY260 cycles on it and is still going strong.
One would expect that if one charge/discharge cycle consumes 25% of the capacity, you would get four times the number cycles than if you used 100% of capacity instead.However, in the insight, I rarely go below 56% SoC and rarely above 65%. Does that increase the 'cycle' count because I'm not using the whole 10-85% SoC range?
To your point, yes, I suspect that each actual day of driving is maybe one or two complete cycles. So yes, QTY1000 cycles is around 700 actual total days of driving the car really hard.Now 928 cycles. Isn't that like 3 years? It's basically one cycle per day right?
An ideal cycle is completely discharging the battery to 10% SoC, then charging back up to 85%.I'm kinda confused with the 'cycles' thing.
Not for lithium. On a NiCd cell, each local maximum counted as a cycle, but lithium doesn't have this 'memory' effect. For lithium, a cycle occurs each time you accumulate 160% total abs(SoC change) (i.e. 80% total assist SoC and 80% total regen SoC). For example, if you consume 20% total abs(SoC change) per day (65% to 55% to 65%), that's essentially 1/8 of a cycle.In the insight, I rarely go below 56% SoC and rarely above 65%. Does that increase the 'cycle' count because I'm not using the whole 10-85% SoC range?
Both of those cells are Panasonic. CMAX and Insight cells.. The picture is from about 3 years ago when the seller didn't know what he was selling. A couple of us set him straight, though.This image is supposed to be a side by side with the CMAX cells and EHW5 View attachment 98106
I've handled so many of those silver cells, that I don't even have to watch the video and can identify it while laying on it's side lol... 100% not an EHW5. It's late, so hopefully tomorrow I will shed some light on a few misconceptions you guys have on these cells.Thanks for posting that graphic. From it, I've determined that the bolt-top cells we purchased last year are definitely EHW5 modules:
No idea yet whether the tab-welded Blue Sky packs are EH5 or EHW5.
Looking forward to reading any clarification you can provide.I've handled so many of those silver cells, that I don't even have to watch the video and can identify it while laying on it's side lol... 100% not an EHW5. It's late, so hopefully tomorrow I will shed some light on a few misconceptions you guys have on these cells.
Yes, but it's a custom project. Based on your previous posts, you're probably well equipped to figure it out.Since I have an Insight now... would say rebuilding it into a plug in hybrid sometime next year, and potentially converting it to a 2nd gen Prius all electric AC system be feasible with the FoMoCo pack,
I still have a few LiBCMs available right now. If you order today, it'll ship this week.I assume you are going to reopen orders for the LiBCM board sometime next year?
Safe assumptions. You'd need a fuse, but otherwise that's the theory.I would assume the electric AC would just tap directly off the battery pack and add a relatively mild additional load.
I haven't looked into it.From what I am reading the Prius AC should work even better with a 60S pack also since it should be able to get to 6000rpm, whereas a 144v pack can only get to 4000rpm (still usable at this performance level).
If you place a 1.7 kW load on the IMA system, the MCM is going to counteract that load by constantly applying 1.7 kW of regen from the engine. If you don't want it to do that, then we'll need to figure out how to lie to the MCM (so it doesn't see this power draw). It won't be hard, but just an FYI.Anyway going that route would eliminate the AC as an engine load (and it burns about 1-1.7kwh) so would work fine for my commute as a plug in hybrid with a largeish pack.
With a cheap scan gauge, you can tell when you're in lean burn when the A/F ratio suddenly jumps up above something like 18.For the time being my NiMh pack seems to be working ok... got 70mpg on the way to work, it was background charging yesterday and I only got 56 pretty sure I wasn't lean burning properly either which I am pretty sure I am now though I don't have any instrumentation to indicate that at the moment.
I'm supprised the IMA system can detect that? Is that due to the load causing a voltage drop or what? I don't see how else if I was directly tapping off the battery. Anyway we can pick that up in a separate thread once I get to that point... I'll probably wait for the next batch since my IMA battery is doing OK at the moment and I'm going to focus on the mechanicals first.If you place a 1.7 kW load on the IMA system, the MCM is going to counteract that load by constantly applying 1.7 kW of regen from the engine. If you don't want it to do that, then we'll need to figure out how to lie to the MCM (so it doesn't see this power draw). It won't be hard, but just an FYI.
Yeah its a NiMH prismatic pack apparently. The peak pack voltage is around 230-240V for the prius since its 28*6 cells * 1.41 etc... so a 60S lithium pack should be very similar to that.I believe some of the Prius batteries used EH4 blue energy cells.
Whatever we found, it's working just fine. I'd like to know what to call it, but I'm not certain @Battery Buyer is going to stick around to dispense his industry knowledge.Shoot. I think he is right, it seems that Honda found a very similar sized cell from Panasonic that they used for the G3.
From a safety standpoint, there's no issue... if the tabbed modules end up having less capacity or a different discharge curve, then worst case LiBCM is going to be angry at you, but it'll still be safe.Are we going to have issues mixing EH5W 18S with Panasonic G3 12S modules?
Only if it's bolted together.Is it possible to convert a EHW5 18S to 12S?
I've tried messing with bus bars before... it's way beyond the scope of anything I'm willing to support. I'm not interested, but if the community wants to figure it out and make a new thread for it, then have at it.Maybe we could cut a bus bar? The battery management leads are crimped on to the welded bus bar connector. It looks like we can bend the tabs to take the module apart without cutting the BMS tabs.
The MCM has indirect access to the battery current sensor (the 'BCS', which is measured by the BCM). The problem with bypassing the BCS is that then LiBCM won't be able to tell you the actual state of charge (because it won't see the bypassed current). Yeah, start a new thread and we can continue discussions there. There is a solution, I just don't want to think about it right now.I'm supprised the IMA system can detect that? Is that due to the load causing a voltage drop or what? I don't see how else if I was directly tapping off the battery. Anyway we can pick that up in a separate thread once I get to that point... I'll probably wait for the next batch since my IMA battery is doing OK at the moment and I'm going to focus on the mechanicals first.
To drive the compressor, I recommend just using an off-the-shelf, open-source VESC controller.Toyota prius's battery pack is about 201V apparently... in any case since driving it with a MOSFET you can modulate that at some value below the pack voltage since you have to generate 3 phase AC to drive the compressor anyway I'd just have to plan for whatever maximum pack voltage looks like the MOSFET he used is AWOL of course.
Yeah I could probably take 150KW VESC | VESC Project and use smaller IGBTs since I don't need to push 100kw etc... lolTo drive the compressor, I recommend just using an off-the-shelf, open-source VESC controller.
Ok I'll fire it up tomorrow and report back if there are any issues.From a safety standpoint, there's no issue... if the tabbed modules end up having less capacity or a different discharge curve, then worst case LiBCM is going to be angry at you, but it'll still be safe.
Ha, that would work. There are cheaper off-the-shelf 300 volt VEST controllers that are pushing 50 amps or more.Yeah I could probably take 150KW VESC | VESC Project and use smaller IGBTs since I don't need to push 100kw etc... lol
Sure, but VESC will be cheaper than LiMCM, plus VESC is shipping now.I guess this will all be a moot point anyway once you redesign the MCM.
VESC is amazing... it'll eventually penetrate the open source brushless motor market just like grbl already has for CNC motion control.VESC seems like overkill but I am also all for reducing the work I need to get to something usable.
Oh, I'm right as rain!Shoot. I think he is right, it seems that Honda found a very similar sized cell from Panasonic that they used for the G3.
