Most of you know your car requires the valve to be adjusted. I thinks its part of your 36k service. The problem most mechs have little knowledge on the insight and are very busy. Its very likely that they will just say that they ckecked the valves.
To check this place tape, whiteout, paint, etc on the engine cover or valve cover near the firewall. Try and hide it so as the mech will not easly see this. After you get your car don't drive anywhere just pop the hood and check your mark.
When changing the oil ask for the three empty bottles back. This will help ensure the correct oil was used. Plus you pay for 3qts and only 2.5qt is used.
For those who like synthetic oil. Synthtic oil Mobil 0w20 is cheaper than Honda Oil. As is Fram Double gaurd filter with teflon.
