Not sure if I've seen this topic covered before but I'll bring it up anyway. Do you guys/gals notice any hesitation in accelaration as you reapply the gas after coasting in gear? Its not really a hesitation but rather a feeling like the fuel isn't coming out smoothly, maybe I'm getting too much gas out when I reaccelerate. The result is a little learch in action and a tendency to push down too much on the gas to compensate. I may be delusional but I seem to be able to affect this phenomena by the angle of my foot on the gas pedal. I was thinking that maybe it has to do with the air fuel ratio sensor problem that I had (check engine light came on for a couple hundred miles, garage said the computer listed the air fuel ratio sensor as culprit). Any thoughts?
Also is there is place on this site to list the age of parts that we have had to replace from normal wear (i.e. brakes, tires, battery etc.)? It would be helpful to develop such a list if it doesn't exist as it would help not only anticipate replacements, but also to identfy any issue that would accelerate wear on such parts.
