I hadn't read the thread in it's entirety until you mentioned a proven method (other than the alternator mentioned in the title)
My mistake, I appriciate the direction! I just used the DR250 unit because it was what I had still in working order
I hadn't read the thread in it's entirety until you mentioned a proven method (other than the alternator mentioned in the title)Why don't you just use the proven meanwell 600w psu in this thread.
Did he die...?^If Eli were still around he might post a 'Picard face palm'...
deserved...^If Eli were still around he might post a 'Picard face palm'...
Soldering to rectifiers with push-on terminals is bad practice because there is a serious risk of damaging the diodes in the rectifier. This is because the thermal connection between the diodes and the connection tab is very good and if you get the tab hot enough to solder to it then you may well have got the diode and / or it's connection to the tab hot enough to do damage.Got everything installed today and it all works good! I used 10AWG wires from the PSU to the car battery cables. I used 16 AWG IIRC from the stator leads to the bridge rectifier, and I used 14 AWG from the bridge rectifier to the PSU.
I didn't have the proper connectors for the bridge rectifier as they were wider than normal, so I ended up soldering these connections instead. I notice though that my bridge rectifier gets VERY hot, not so hot you can't touch it, but you'd be dumb to leave your hand there. Is this normal? or should I swap for my spare?
Definitely hard to soften the solder!!!!The solder on the meanwell psu pcb was very high melting point and my normal soldering iron set to 450C would not touch it.
I had to use my 100W almost glowing red uncontrolled iron (light sabre) to melt it..
Thanks a bunch for the heads up. I am fixing the issue right now. I should have known from experience. Regulator rectifiers that get hot are more likely to fail.Soldering to rectifiers with push-on terminals is bad practice because there is a serious risk of damaging the diodes in the rectifier. This is because the thermal connection between the diodes and the connection tab is very good and if you get the tab hot enough to solder to it then you may well have got the diode and / or it's connection to the tab hot enough to do damage.
Unfortunately this damage is not immediately evident but leads to a serious reduction in the life of the rectifier.
How do I know? A product I was once responsible for began to fail in just this way after an unauthorised change in production method. ("We ran out of push on tags so we soldered the wires directly") Cost a lot of money and product reputation.
I assume you have also used heat transfer paste to aid heat transfer.
I definitely didn't think about adding thermal paste to the rectifier... I've been driving with this setup for a couple months now, so is there a chance that the rectifier has been damaged by running hot for that long? I need to reattach my PSU to the compartment wall anyway (turns out EVERYTHING shakes loose over time if you don't Loctite it), so I was thinking about swapping in my spare rectifier while I'm at it. I'd have to take off all that heat shrink and Loctite I put on last month, though, so if the rectifier is probably fine I'll just apply thermal paste and call it good.Regulator rectifiers that get hot are more likely to fail.
Couldn't hurt to change it, and carry your current one as your spare. That's what I'm doing, this way I still have a working spare with questionable life left, and I am less likely to have to swap it on the side of the road.I definitely didn't think about adding thermal paste to the rectifier... I've been driving with this setup for a couple months now, so is there a chance that the rectifier has been damaged by running hot for that long? I need to reattach my PSU to the compartment wall anyway (turns out EVERYTHING shakes loose over time if you don't Loctite it), so I was thinking about swapping in my spare rectifier while I'm at it. I'd have to take off all that heat shrink and Loctite I put on last month, though, so if the rectifier is probably fine I'll just apply thermal paste and call it good.
