2 days ago I was driving uphill and the idle stop was working fine while I stopped at the light. when the light turned to green I depressed the clutch , shifted to 1st gear, had the right foot one the gas and released the parking brake . But engine won't start and car rolled back almost hit
someone on behine
. u know why? I 'm a short guy, when the car is on uphill my leg is not enough to depress the clutch fully down so the car will not start. after home, I grabbed a 16mm wrench and crawled under the dash panel , loosen the lock nut on the clutch safety switch, turned the switch 4-5 turns forward, retighteened the lock nut. done.....
now ther is no need to fully depress the clutch all the way down to the floor, and changing gear is very smooth.
someone on behine
