I didn't think it was that full, but I drained approx .6 qts the other day and my mpg started climbing again....my average had been about 71.4 a tank, but I couldn't break a 69 avg with super conservative driving; after the removal - avg on this new tank of gas is 73 and holding (with M1 0w-20).
btw - 90°F++ temps really seem to zap the IMA battery.
my dealer overfilled my beloved CVT insight. I discovered this when my engine clunked to a halt in the middle of the highway, requiring some sweat inducing measures to get off safely...
(basically I shifted to neutral, grabbed the steering wheel very carefully and tightly, and made it through traffic to the shoulder.).
It restarted and I got to a nearby dealer, who checked it out, said the [mumble] had shut off the engine due to the high oil, drained out a bit, and everything was ok.
Anyway, I didn't notice any lower mileage, but given the driving conditions I might not have.
The bit about recals due to the weather are, I suspect, more to do with the added electrical demand from the air conditioning. I've noticed that when I keep my 12v -> 120VAC adapter in the cigarette lighter, or if I use a/c when in city traffic, that I get plenty of recals. If I'm using a/c on the highway there's no problem.
Same thing happened to me last week. Oil Change at Honda and mpg drops from 75 to 68 on a tank. Low and behold the dipstick is pegged. The car has not stopped, but the engine sounds a little different. Guess I know what I'll be doing this weekend. And they charge more for an Insight because they have to remove the panel to get to the drain plug.
now where can I get that fumoto plug again?
I imagine the warning to all of us should be that if Honda changes your oil, check the level before you leave, or maybe pay. jeez.
Can anyone tell me what the proper level on the dip stick should be?
I thought only the Prius drivers were concerned with overfilling the crankcase and hurting their fuel economy.
Ever since I went to what was my second service department and had my engine oil overfilled, my coolant underfilled, and they tried to sell me new front brake pads at 42,000 Kms - I now service the car myself.
A friend of mine got a new motor from Honda when his Insight developed an oil leak at 100,000Kms. I wonder now if his engine had been overfilled and the additional pressure blew out a gasket.
Bill
A few things that may help others here after my "experiments" last night.
The dip stick was more than 1/4" above the top hole and I became a bit spooked about taking out the drain plug with the possibility of damaging the pan from what I've read here at IC.
1. Bought a very good siphon at the local auto store and siphoned all the oil out of the pan in about 5 minutes! (engine very warm, and after the first batch was out I raised the car with a floor jack on the drivers side to "tilt" the remainder out. that was another 1/3 pf a quart.). Funny slurping sound at the end, like a kid with a slushee. but that's to be expected. Can't wait to do the lawn equipment, snow thrower, Pilot and Accord this way.
2. Measured what I took out... 3.4 quarts!! - yup - no kidding.
3. Put 2.6 quarts oil back in (filter still aok, changed 2 weeks ago).
4. Turn the "Key Lime Pi" back on - engine immediately sounded much better.
5. Check dip stick 3x - level was dead center betweeen both holes.
6. calculated that Honda overfilled the car by nearly 35% (accounting for some oil still in the filter) of the spec...nice job....
I'll see if I the mpg goes up once I get the car back on the road next week and report back..
Wayne
