1 - 3 of 3 Posts
Needing to replace the 15 inch steel wheels on my 2012 Insight, not looking good with rust. Wanting to go with alloy wheels. Wonder if anyone has found something from a different Honda that also fit the 2012 Insight. New alloy wheels are a pretty penny!
2013 Honda Insight
You should be able to run wheels off of a Fit of a similar age range, or even older model civics as long as they are the same bolt pattern, 4x100. Stock Insight wheels are 15x6 With an offset of +50mm.
Also, check facebook marketplace, you can find pretty good deals on there, just search "4x100 Honda wheels" and compare the wheel specs to the standard specs. You can use a visualization tool like "willtheyfit.com" to help.
2009 Insight gen 2
Any 4x100 wheel with et for fwd car should be fine but don't forget to get the center ring. There is plenty of options old Civics, all Fits, old Golfs, small Toyotas, Minis etc. My winter wheels are off a old Civic and summer wheels were installed on a Renault, so don't only search for Honda specific wheels.
Wheel Tire Snow Vehicle Car
1 - 3 of 3 Posts
