^^ Did you get to drink the potable water in the bathroom?
I was pretty much in 1st gear the entire time of the drive up....and down. Hehe
That was the outcome I was hoping for but clearly was the total opposite for me. Either way, glad you and I made it out!I spun out my 98 Acura CL 3.0 on the I-85 on ramp about 5 years ago... conditions were hot day (so the asphalt was adding some oil to the road), + rain + ramp was very smooth due to wear. When I stopped I was facing the guy behind me on the ramp. Thankfully was only going about 15-20mph and nobody touched and we all drove away with nothing but a little embarrassment.
Couldn't have said it better myself.I know you are disappointed to lose the Insight, but cars are replaceable, unlike yourself or loved ones. Glad you are OK!
Yep! Are you superstitious? HeheDoes this happen to be the car that the core support in my car came from?
Another guess is I may have experienced an early tire failure or even a catastrophic wheel something of that nature. The right rear wheel was obliterated in the crash so it's hard to say. HWY 90 going towards downtown is pretty rough before I-10, especially after the storms we've had and the cold weather that's created more potholes than usual.@Tekuno Ichigo very sorry to hear about your rather shocking incident. I hope I hear that you both recover completely. Thank you for sharing this. In the video there is no puddled water that I can see, nor does it look to be raining very hard. Have you looked into causes other than hydroplaning? I sure wish I had a place for #3557 so you could take your time in the process, but I am usually in AZ these days. I hope that someone in San Antonio area steps up. Hopefully you will keep us posted.
I'll be in touch with ya later this evening if that's okay. Right now another member and I are trying to work out logistics but he's in another state. Plan is to revive another car using the good parts from mine, but I'll see what we can do to work things out so I can revive other Insights with what I have to give.I have 50 acres near Bryan, Tx. We could work a deal maybe. I will be in San Antonio tomorrow at a conference(driving my 2000). You can text me at 979-224-0062.
Very generous offer but my current living situation isn't well suited to take on a project like that at the moment. If I had more space and time to do it I would definitely consider it. Thanks!Sorry to hear about the G1. I have stripped most of my cvt G1 but if you need a donor rear body, i have one if you want to take ownership. Maybe you want to go through a body shop to use my back end. This vehicle is free for your taking. You will need to come get it if interested. Oh, im in Texas a near louisiana border. Mooncar
A better quest if one that is off the road will be on it because of your car. Best cars ever. I would offer some cash and would pick it up from wherever it is if the other deal falls through.Another guess is I may have experienced an early tire failure or even a catastrophic wheel something of that nature. The right rear wheel was obliterated in the crash so it's hard to say. HWY 90 going towards downtown is pretty rough before I-10, especially after the storms we've had and the cold weather that's created more potholes than usual.
Looking at maybe a Citrus or a Monte Carlo Blue but beggars can't be choosers at this point, lol.Wow, so glad you both are okay... That video turned scary so quickly and is a good reminder for me to refresh tires next rainy season 😞
You did it well, 500k is a real accomplishment most cars never dream of. Time for the next color?
I want to offer one piece of advice on this situation --- these cars like to "skate" as in the water cuz they are so damn light --- BUT, they also have that dreaded narrower rear track - generally the cars front wheels plow a path for the rear to settle --- not with the G-1's in fact they are lethal that way, the rear is much lighter and it's tires are half exposed to fresh water, good rubber on these cars are a must, also - I made 1" wheel spacers for my rear wheels and kicked them both out picked up two inches of track - the car is "almost normal" way less squirrely in the slush and i do have a little more confidence with the rear in the rain,
You "swapped ends" in that vid --- your *** end hydroplaned... glad U two are ok.
I put 32mm spacers on mine back in September. I don't know if they would prevent an accident like this but the car feels more stable. I don't have skirts, so I didn't have to modify them. Another forum member modified their skirts by heating them up but didn't give details!On the next G1 I get, I will definitely find ways keep the rear from doing what happened here. Still amazes me how quickly this went sideways, even at such a relatively low speed on the highway given the road conditions. I'm almost tempted to even make a slightly wider skirt for the rear to square the rear wheels to each other. Are you using 25mm spacers per wheel in the rear?
II installed 32mm spacers a couple days ago. I heated the fender skirts and bowed them out a little to provide needed clearance. I have had no rubbing even over big bumps at speed. The car seems more stable on the gravel. The camber increased a bit so I will shim the axle shafts more to neutralize it. So far I like the way it drives
If you get a chance see if you can still find the date on the tire that blew up. I suspected it maybe sitting on the side of highway 90 somewhere though.Makes me wonder if the RE92s I put in the back were "new but old". PSA: check those dates of manufacture, and inspect your wheels
Thanks for the kind words. I finally got my rental this afternoon so I'll drive across town to check out the damage and collect some belongings.I'm glad you're okay, sorry for your loss. I hope it doesn't take too long to find a new one. Do you have another means of transportation in the meantime?
I
I
The timing of your conversation in that video is crazy. "You get bored, You're imagination runs rampant, and then... Oh $#!7“
