Dear Members.
I all ready have the radiator block mod on both my vehicles, and that does help them to warm up quicker on cold days, however the cold air intake temp is an issue, with LB more difficult to obtain and maintain.
I have read the hot air mod posts and other pre heat ideas, and have been thinking about a couple of solutions.
1) Use a small cpu cooler radiator in the air intake system to pre-heat air.
Use warm water from return side of car heater system diverted through this small rad before going back to engine block.
Something like this rad 120mm square should be fairy easy to incorporate into air intake system. Smaller sizes are available.
http://www.overclockers.com/articles1140/
I would use the return side of the car heater system to avoid too much of an impact on the car heating! This use of warm water rather than hot would also probably put the intake air temp rise into the optimal range. Use of the hot water might be too much heat! This could be controlled by an electronic divert flow valve.
2) Use the above radiator idea, but collect heat in the form of hot water from the exhaust system after the cats. This would require the fabrication of a section of exhaust pipe with an outer low capacity water jacket. Insulated pipes and a small 12v cpu cooler pump would then feed water to the air intake radiator. Replacing the first muffler/exhaust box with a heat exchanger assembly might be the best bet.
Low power 12v 12w pumps are here http://www.xspc.biz/pumps.php
I'm now looking at the Insight engine bay and working out were to put the stuff and what to try first. Option 1 is probably the easiest so i'll try that first. I appreciate there is little spare engine heat.
It would be pretty easy to control any pump via a simple electronic stat in the post radiator air intake system to avoid over heat of intake air.
I haven't looked at the fuel supply pipe run yet, but again low temp water say <35C could be used with a heat transfer jacket on the fuel pipe to pre-heat fuel if it is accessible.
I'll keep you posted of course.
Anyone know the air flow in CFM at the air intake at an engine speed of 2500rpm? This would help with intake radiator sizing so as not to restrict air flow too much.
Regards Peter
Regards Peter
