I've read and troubleshot all I can stand but have not been able to resolve the problem. -HELP-
2002 CVT Insight/180k miles. Probably original battery (yellow stick sleeves).
Background:
A few months ago my IMA went south with typical unbalanced cell symptoms.
I removed the NIMH sticks and low current cycled each stick two times in an attempt to recondition. I also purchased a used battery from Bumble Bee in case some sticks were too far gone. Picked out the sticks that had the most energy capacity and re-installed in vehicle after discharging each stick to 1v/cell. Also installed a RB Battery grid charger. Grid charged battery for 14 hours and had 156v on meter. Was expecting to get closer to 180v. Car started with IMA and went for a test drive. SOC meter was working but erratic and never had IMA assist or charge. IMA light on. Grid charged for another day and voltage was about 177V.
Current Conditions:
IMA light is on. Instrument SOC, assist and charge lights are completely off although do cycle on with ig on. 12v is charging until 4200 RPM, then brake and battery light turn on but turn off after a couple of minutes after reducing RPM. DTC codes P1576 and P1648 set immediately when ig on. P1445 sets after driving. Battery will grid charge to 180v in a couple of hours but self discharges rather quickly.
I've checked all the fuses including the 100A semiconductor fuse and the smaller pack fuse. All read good continuity. All connectors are plugged in properly and no broken wires.
I'm prepared to order a set of new sticks from Bumble Bee but want to correct any other problems prior to such a large investment.
Can a bad IMA battery cause these DTC codes that disable the IMA? Any suggestions on what else to check?
Background:
Current Conditions:
