We have seen Bluebelle's passenger window slow to a crawl and nearly seize up once. We are going to try the lube trick with Silicone.
My feeling whan pulling on the window was that if the motor mechanism were to actually fail completely, it would lock the window in whatever place it was at failure.
I expect this has happened to yours, and no amount of manual pulling with fix it so you need to bring it into the shop.
It probably would be worth trying to get it paid for by Honda, even if out of 3 years, because it appears to be a problem which is more common with Insights than it ought to be!
