Avoiding the political issues in that other thread, there's still a technical one:
"If Schwartzenegger becomes govenor, someone has offered to convert one of his five Hummers to run on hydrogen. This guy has done it before and AH-nold sounds serious about it. This is hydrogen internal combustion like what BMW is working on. It's estimated the Hummer's mpg will double from 11 to 22."
That, I do not believe. OK, you've got some problems defining exactly what constitutes a "gallon" of hydrogen. Of course, seeing as how it's a gas at ambient temperatures, you can (theoretically!) compress it without limit, if you have a container strong enough to hold the pressure, so a gallon could contain almost any amount of hydrogen. Unfortunately, we don't have the technology to reasonably do more that about what a Scuba tank holds - maybe 3000 PSI.
If you go by a sensible measure of equivalent energy content - how many BTUs you get out of a given mass - I bet you'll find that Arnie's Hydrogen Hummer will use almost exactly the same amount of energy going from A to B as a normal one. Probably a bit less, 'cause of the extra weight of the hydrogen tanks.
