A little bit of background..... I have a 2005 1st gen insight (my second insight) with 96K miles. Bought it with a "bad" refurbished battery. The current battery had been replaced about 5 years ago but the previous owner let the car just sit to the point that the IMA stopped working prior to when I purchased the vehicle. I Installed a grid charger and I now grid charge the battery whenever the IMA light comes on and then pull the negative battery cable to reset everything (about once a month).
The car goes into auto-stop like it normally should. If you pump the brake it will auto-start, putting it into 1st gear also makes it auto-start. The only time it doesn't seem to work is if you let the car just sit so that the SOC decreases to the point where it should turn on automatically. When the car has between 1-3 bars left on the battery indicator the 12V battery light will come on and the engine won't turn on. If you put it in first gear quickly when this happens or pump the brakes it will restart the normal way. If you wait long enough I have to use the key and restart it with the backup starter (still showing 1 or more bars on the IMA indicator). All of this happens without any IMA light. Reset the BCM with no improvement.
Has anyone else experienced this? Were you ever able to solve the issue? It would just be a minor inconvenience except that I would like to leave the ignition on for an extended period of time with the engine toggling on and off as needed.
