Back-up (Reverse) Light Sensor in Transmission may be bad(Gen 1)
Hello,
I seem to have lost my reverse lights, while the fuse is still good.
I tapped 12V of power on to the reverse lights at the housing. They lit up. Bulbs are good.
I found the back-up light sensor in the transmission. I want to try completing the circuit on those wires and see if it is a bad sensor. I hope shorting the wires together might work.
(Found location of sensor on Majestic Honda under "Transmission Housing". It is parallel with the ground...toward top of trans.)
Hello,
