Hi all. After a discharge and grid charge and pulling the battery terminals off I can no longer get the IMA to reset. I get no state of charge reading at all even after 20 minutes of driving. The 12 volt is charged up as well. Even tried with a different 12 volt. The car is now starting off the 12 volt instead of the IMA I believe. There is a slew of other lights as well. Check engine, maint required, IMA, and ABS is the newest one.
There were some crummy grounds but they are cleaned up and tightened as best as possible. I'll just replace a couple of them shortly. The 12v starter is working easier now though.
I'm hoping it's a relay or something. I've visually checked all fuses under driver side and all in the engine compartment. I'm not sure where else to go. The 100 amp fuse on the ima looks good and has continuity but apparently they can trip at loads still.
The only code was p1648 when I check at autozone and the forums basically say check the grounds.
The last thing to happen before the problems occurred was a grid charge, then an a quick commute 10 minutes both way where perhaps the correct fuse wasn't pulled for a recal. Perhaps that messed something up.
Any thoughts on how to continue trouble shooting. I'm at a loss.
