Figure that a waranty, like any form of insurance, is actually a form of gambling. In this case, they are betting that the battery will last at least 4 years or 80,000 miles and you are betting that it won't. Since they are making up the terms, and they know that different batteries will last different amounts of time even if conditions were the same, and in these cars conditions will NOT be the same. They have to figure they can afford for some of the batteries to go bad, but they want to minimize that number.
Some batteries might make 8 years, 160,000 miles or more. Some might make 3 years, 60,000 miles. The waranty just tells you that you can depend on getting that much out of the cost of one battery. It is a "limited" waranty, so, I believe, you pay for the portion of the battery life you got and get refunded the portion of the expected battery life you didn't get. If the battery lasts half as long as they guarantee, you pay half for a replacement.
Apparently, exceptionally hot climates shorten battery life, unless you actively defeat the heat buildup in the car while it is parked (hence all the discussion here about tinting in Florida).
