1 - 8 of 8 Posts
Hello everyone,
Curious question for you - sometimes I'll have the battery at about 70%, and after driving for a 5-10 minutes, using no green charge bars (aka level, steady-speed, highway driving), it'll pop up to 100%.
Not too strange, I guess.
Sometimes as well, while driving about 10 minutes incredibly lightly, while using no orange assist bars, it'll slowly trickle it's way down to just 2 orange bars.
This seems to be occurring more and more often.
The batteries have about 70k miles on them.
Does anyone have any suggestions? Think it's time to pull the sticks out, and do a reconditioning?
Thanks!!
There are Recalculations. The IMA light is close behind. Grid charge now.
Sounds like your battery's on its way out.
Probably no need to go as far as stick-level reconditioning right now. Do you have a grid charger? The cells might just need balancing (which a grid-charger charge can do), or you might need to do some charge/dischrage cycles to help bring back some capacity.
Thanks for the quick replies!
Please let me know if my understanding correct - a good grid charger will force all of the batteries back to 100%, and any battery that reaches 100% before the others will just dissipate the extra charge as heat? Also, once this happens, every battery will be fully charged, and therefore balanced? The computer will then recognize this full charge?
Also, if the batteries are on their last legs, wouldn't it make sense to do the stick-by-stick reconditioning? Shouldn't this also balance the batteries if they are individually recharged to 100%?
Lastly, with respect to grid chargers, I've seen tons of options, and have read lots of articles on building and buying. Are there any grid charger models any of you would recommend?
Thanks!!!
Lots of reading here at ICN needed Grasshopper. Spend a few hours searching with the search mode located at the top of this page.
To fix something, you start with the easiest and then work to the hardest, if needed.
HTH
Don't worry, the amount of research performed could probably be counted in days by now :) :)
Based on the research, I assume these assumptions are somewhat accurate:
1. Grid charging charges all of the batteries to 100%. Any batteries that reach 100% before the others will merely take the additional "grid charging" as heat. Therefore, the batteries need to stay cooled during this process.
2. Stick-by-stick reconditioning is much, much more work, but probably one of the best ways to get the battery pack performing at its peak.
A question for those of you on this thread - do you have a grid charger you personally recommend? At this time, I'm looking to purchase rather than build one.
Thanks again!!
1 - 8 of 8 Posts
