Now we have lots of projects ongoing, but I thought we could discuss this wild idea.
The OEM BCM is very rugged, proven, and has all the peripheral psu/signal conditioning stuff on board.
But the fly in the ointment is the ancient 112 pin QFP Hitachi H8 processor, it's years old and cannot be programmed by us.
It's seems rather a waste to discard the pcb when it contains so much good stuff .....
The million dollar question, can we replace the oem processor with one of our own using some sort of QFP adapter daughterboard etc?
Assuming we can desolder the H8 and solder in our board, it would only need to carry a small number of parts.
A straight lift from the basic BCM Replacer design would mean we only need..
1) PIC18F66K80 cpu
2) Mega 88 Video chip
3) CAN interface chip. (optional)
4) A few supporting crystals and caps/resistors etc.
We could leave the BCM connectors completely OEM, no adding pins etc.
Our daughter board could have a little independent micro header connector for video/keypad/can bla bla.
A little hole drilled in the case and external breakout box with rugged full size rca connectors etc.
Now we are currently full steam ahead with the full BCM Replacer, but if people want to thrash this about then it would be interesting.
We won't be diverting resources time / into this soon but it might be worth exploring in this discussion.. :?
So the difficulties I see.
1) Unsoldering H8 CPU without damaging board.
2) Soldering an new adapter riser board in place to the old 112 pin QFP CPU pads.
3) Decrypting all the H8 CPU pin functions and relating them to the on board functions.
(With the H8 data sheet and some basic visual inspection and electrical testing I think we can work out what goes where)
Temp sensor input, current sensor inputs, voltage taps etc etc
There is quite a bit of real estate round the cpu on the OEM pcb.
We can cut the alloy strengthening bar out of the old case if needed.
This is one idea for getting something attached to the OEM pcb. ..
www.advanced.com
Ideas welcome. Over to you...
Here's a couple of old YT videos of me looking at the CPU and voltage tap modules..
1) PIC18F66K80 cpu
Advanced Interconnections | QFP Adapters
Advanced Interconnections' patented Solder Sphere Interface streamlines package conversion for use on PC boards with existing QFP pads.
