Has anyone removed the duct behind the passenger seat and let the space beteewn the Ima case and panel behind the seat act as a plenum? Seems like this may allow for more airflow.
That's some clever s**t right there...
Are you really charging your (stock?) pack at around 60 amps, close to 190V? Isn't that bad for the cells?
At sustained levels without supplemental cooling and done on a routine basis, yeah, it's potentially bad, but it's still basically ~11kW limited.Are you really charging your (stock?) pack at around 60 amps, close to 190V? Isn't that bad for the cells?
We may have our answer in the HCH2. The 06-08 with it's much tighter spaced sticks and offset/nested spacing is the second worst pack ever made with a 1 in 6 failure rate in 5-7 years. The 09-11 increased the spacing slightly. Worst pack ever made with a 1 in 3 failure rate in 3-4 years.On the subject of pack cooling...
In the Insight battery space, would it be better for pack performance and longevity to have cells packed closely so each cell is more likely to be the same temperature, or packed with space for presumably more air flow between cells, better cooling, yet perhaps risk having cells at more varied temps?
So did you water cool your packOH THE HUMANITY! SCREW TRYING TO RECONCILE THEORY WITH REAL-WORLD!!!!!!
