1 - 19 of 19 Posts
Discussion Starter #1 (Edited by Moderator)
Moderators Note:"FYI, this shouldnt be attempted unless you have a way to monitor the vehicle temperature by the odb2 port and you should make it easily reversable incase the temp gets warmer faster than you expect."
ive seen this before here where people talk bout covering the grill of the i2 in winter time, and they actually get more mpg
i live in socal and its been pretty cold here lately, also my mpg is dropping, i was wondering if this really works, how cold would it have to be for the car to be safe and not have problems if i block the grill
mornings get as cold as 50 and during the day it stays 60 but never hotter than 70
is that not cold enough?
should i just forget it?:-?
The main reason I do it is to get the engine up to it's ideal operating temperature.
I suspect your engine is fine with an OAT of 50. Do you have a ScanGage or something to monitor water temperature? With Springtime around the corner, I don't think you should worry about it.
I have an Ultragauge on my current car with temperature alarm set at 210 F just in case.
The opening on the grill is about 1.5" X 12", the car a smart for two. Today with a ambient temperature of 50F the indicated engine temp got to 195F which is the high point normally. When it starts to get higher than that I will just open the hole a little.
Car warms up much faster.
Moderator
I wonder how this happens. If the thermostat is rated at 180 deg F, or 190 deg F, then the coolant in the engine will heat up to that temperature in X amount of minutes, at which time the thermostat opens. The water in the radiator is unaffected until the thermostat opens at the pre-determined temperature. So, the grill block should have no effect on how fast the coolant in the engine block reaches operating temperature.
I'll give you two things to think about.
1. What do you think happens to cold air that passes through a cold radiator? Where does it go from there?
2. What do you think happens when that thermostat opens? What happens to the 180 degree water leaving the engine? What happens when it is replaced with 35 degree water?
Moderator
Yes, it may make a difference if you drive before warming up the car. And the engine temp may take somewhat of a dip (although I haven't noticed much if any, at 40 deg F temps on my G1 with Scangauge monitoring), when the thermostat opens.
But I think it takes the same amount of time for an engine to reach operating temperature with or without radiator block. (unless the car is driven while cold)
i dnt have a scangage
i wish i knew what it was....
i got no idea of what anybodys talking bout
i rather not blok the grill haha:-?
Blocking anything completely is a bad idea. Your license plate mod should account for something as it partly blocks thelower grill. Last summer I ran half a block with no problems even with ac use. In winder I blocked all but an inch of the lower grill.
Even if the t stat opens at a certain temp to allow coolant to go through the radiator, the blockage reduces the air flow through the engine compartment that can cause some cooling and delay the engine warm up. Furthermore a t state does not completely block the flow of coolant, it leaks and some flows through the radiator anyways even if its closed.
From what I can see out engines like 177 degrees. I do not know when the t stat opens, but Id try a colder one next time its replaced or if I get around to it.
engine block heater
If you get the engine block heater would it solve this problem? Just plug it in over the night. And then you could also say you have a plug in hybrid.
I believe there is also a significant savings in cooling drag with the radiator block.
In aircraft, you can get save a lot of drag and get extra speed by altering the size of the cooling exits using variable cowl flaps. I think any reduction in flow of air through the engine compartment / radiator saves drag.
I believe blocking the air conditioning portion alone (if you don't use the AC) would represent a savings.
Imagine how much drag a radiator would be if you mounted it on top of the car sticking straight up. Inside the engine compartment it's hidden but it's still a major source of drag.
BTW, doing some reading on this subject I found some interesting info. The P-51 mustang had a belly mounted radiator but the design was such that it had zero cooling drag. The heated air exiting the radiator exit expanded enough to add a little "jet engine" type thrust, enough to offset the drag of the radiator itself...
Moderator
^ That's an interesting design.
Also it just occured to me that the OP was asking about "grille block" and some of the info may have been confused with "radiator block".
Grille block covers or blocks frontal area body opening with a shaped foam or fiberglass "plugging" the opening in front of the radiator and rad block is just a piece of flat obstruction directly in front of radiator. The two theories are:
- Grille block helps with reducing aerodynamic resistance. (Smoothing out the front.)
- Rad block is supposed to help by helping to warm up engine faster. The idea is to block the air from flowing through the engine compartment.
A radiator block (cardboard in front of the radiator) should reduce drag similar to blocking the actual grill. It's not intuitive but...
Imagine if you will the scenario where you block the radiator entirely. No air can flow into the grill opening since there's nowhere for it to go. Instead you will just build up a slight high pressure in the grill opening. The airflow will encounter this high pressure and be diverted around, similar to if there was a physical obstruction there.
Another example: Imagine the aerodynamics of a solid cylinder. Now imagine the aerodynamics of a bucket with the opening facing into the wind. Which one has more drag? The answer is they are almost the same.
Yet another example, imagine a hollow point bullet vs. a traditional round-nose round. Which one has better ballistics? Believe it or not the hollow point is actually slightly *better*. It's true. Match shooters use hollow points as target rounds. (The reason it's slightly better is because the center of mass is further aft)
Anyway the point is that when you reduce the airflow through the engine compartment you reduce drag, whether you block the air in the entrance, the exit, or anywhere in between.
I agree with ackattacker and seen it in person on wind tunnel models. (40% and 50% scale race and production cars)
The only detail is that the air-box in front of the radiator has to be sealed for this to be 100% true. Blocking at the radiator will increase the air-box pressure and a good part of that air will end up slipping through open gaps, but yes the increased air-box pressure will force more air to divert around the car reducing drag.
I worked as a Model Maker for five years.
Been there, done that, got written up by my home owners association. Also it had no effect that I can measure on fuel economy. It just reduced warm up time by a few minutes.
Ive found that blocking the opening on the front of the vehicle does more for faster warm ups, noticable mpg savings as well as better acceleration at or above highway speeds. I tried the radiator block, but it actually hurt mpg. On the other hand I found my addition of foam inserts between the condensor and radiator that would require air to pass through both to actually help mpg.
For a car that holds less than a gallon of antifreeze we got one large radiator.
I have a question. If grill blocking does what some folks claim it does, then why didn't the engineers at Honda incorporate a grill block(partial or otherwise) into the design of their vehicles?
They design the vehicle to operate at the extremes of climate (hot day, climbing a mountain, full load) without overheating and without requiring mechanical intervention by grandma Jones driving over hill and dale to see her grandkids.
They could have incorporated a variable opening controlled by computer and servos, but that's complex and expensive, and it's one more thing to break. Expense vs. reward wasn't there.
Check out the 2012 Focus if you are intereted in a very good variable grill block.
FYI.......A lot of Semi's have basically the same system.
FYI, this shouldnt be attempted unless you have a way to monitor the vehicle temperature by the odb2 port and you should make it easily reversable incase the temp gets warmer faster than you expect. This car seems to like 177-181. Any more hurts your fuel economy.
1 - 19 of 19 Posts
