The Honda dealership very kindly replaced Papaya's driver's side brake light on Friday because it burned out. I didn't even think about changing it myself after a recent experience changing the rear turn signal bulb on the Ford which took two hours and involved pliers, a file, sandpaper, scissors and and superglue! I can tell you it looks scary behind that Ford lens since I got a hold of it! :shock:
Honda charged only for the bulb ($3.55) and they were able to change it out fast. Everything seems to be working perfectly. I'm grateful.
I have a quick question about the bulbs. IC Search mentions a twin filament #7443 (newer version of #1157) as the brake light bulb. The dealership needed to use an Acura 12V 21W/5W bulb part #34906-ST5-003 because that's what was in stock and matched the wattage. Are there any significant differences?
