After reading about John's use of a F-150 heat shield and getting a +45 degree temp increase I figured I could improve my simple dryer hose. During the Christmas Holidays I put my Insight up on Jack stands and looked at how I might improve the hot air intake. I decided that if I could get +20F from one catalytic converter using both would be even better. Since the exhaust seams to travel down the length of the car in a bit a cavity I figured I could block this off to outside air. Since the length of the intake was fairly long I figured I would put a bit of a scoop to push the air up to the airbox. THe intake consists of several pieces.
1. My 2inch plumbing elbow connected to the air box
2. A 4in dryer vent aluminum crimped over the 2inch elbow
3. A temperature probe inserted into the dryer vent at the connection of the above two items
Picture shows the above items
http://webpages.charter.net/r1957/Flipper/airbox.JPG
4. I used reflectex and aluminum duct tape to create a enclosed area surrounding the catalytic converter. This area connects to the cavity under the car moving back toward the exhaust resonator.
http://webpages.charter.net/r1957/Flipper/frontview.JPG
http://webpages.charter.net/r1957/Flipper/engineview.JPG
5. Lastly I used a home heating vent to create the air scoop.
http://webpages.charter.net/r1957/Flipper/airintake.JPG
I have had this on my car for about 5K miles and it seams to be holding up well. The lowest gain in temp I have seen is +70F but if I am in traffic or crusinging around town slow then 100F will be seen. The normal highway gain is 70-80F with uphill runs heating the temp occasionally to 90F. The gains in fuel economy are noticable but certainly not at summer levels (Guess the cold winter blend fuel) keeps a lid on how much the air temp can help with the mpg. Another advantage is that even in freezing weather the car warms up much quicker making autostop available. On the downside the scoop will scoop snow which I learned the hard way. Fortunately I didn't have to drive through very deep snow for long.
I have used a OBDII scan tool and the intake temp is usually a 5-10F below my temp sensor value. I suspect this is because the sensor is in the aluminum vent and is getting conducted heat from the metal. I have also noted that the oil temp is reading a bit high (180-190 range) and lastly the water temp stays around 197-199F.
I plan to leave it in this configuaration until mid to late spring but Robert had an excellent idea about wrapping springs around the catalytic converter. This would conduct the heat and provide a larger surface area for the heat transfer to the air. I think I may try this route next winter. Have fun, Rick
