Does anyone else experience "bunny-hopping" (repeated short surges and slackening off of the engine power causing car movement jerkiness) when the car is loaded, going up steep hills, when foot pressure on the accelerator is steady?
Is it a typical CVT issue?
It's certainly not a cold engine issue, and on other terrain the engine runs smoothly and well. There is plenty of power to go up the steep hills when loaded (4 or 5 people), but the CVT transmission can't seem to choose a particular engine speed relative to vehicle speed. This happens on both the D and S gear shift selections. Even on S, paddle-shifted to gear 1. The last resort is L (Low) gear shift selection, and it is slightly better, but it can be a hassle changing down to this gear, because you have to pull both paddle shifts simulaneously and wait until the L shows in the shift indicator, meaning you usually have to stop to do it.
Otherwise it's great little car.
2013 Insight EX Nav (also known as model SN), New Zealand
