Can I drill into this panel? Or, how would I remove the cowling so I could safely drill here?
is there wiring or anything else back there, that I don't want to drill into?
I'd prefer to drill into the cowling piece without removing it.
But if removal is the only safe way, how do I pull the cowling?
I want to attach a mount for a small dash clock (actually a Honda-branded watch) in this triangular area. Where the horizontal ridges are. I’ve used good quality double stick tape, but it fails in the summer heat.
I want to craft a panel that I'll screw to the plastic. Just 2 screws, into the recessed part between the horizontal ridges.
Then I can mount the watch to the mount panel.
86139
It’s pretty safe to drill there.
86140
86141
Scott
If you didn't do it yet, why not just do it on the other side where the little slat things in the right corner can be pulled off to reveal a factory mount point?
Oh, sweet. It pops right out. Maybe I can find a nice small 12V led clock with a seconds display...
