Up for sale is a fairly rare gen 1 Honda Insight. The first hybrid sold in the USA and has incredible fuel economy numbers, This one gets around 50-70mpg. Key notes: - 135,000 miles - 5 speed manual...
Fight high gas prices with this great 50 MPG 2000 Honda Insight Hybrid! Car is super clean in and out and has been an Arizona car its whole life. Always garage/carport kept as you can see from the...
But if you zoom in the picture 7/12 it's showing a low/bad IMA indicator.
So the IMA battery is tired, which makes sense because it has been replaced in 2018, 4 years ago.
This one won't last long. Heck, I'd fly out myself if I were in the market. Pretty rare example these days. I'd check the compression and away I'd drive, all the way to VA
I don't see the IMA light? It should be in the bottom right, correct?
Only lights I see are:
Maint. Reqd. = Needs oil change, reset, or bad trip button
SRS Airbag light = Not sure why this is on. Wet seatbelt?
Seatbelt light = Seatbelt isn't fastened
Brake light = Handbrake is on
I don't think the battery would be shot being only four years old as long as the car was driven, right?
You make a good point. I've had my SoC indicator below 50% fairly often as well, just depends on how much city driving or "racecar-ing" I've been doing. Hard to tell from a static image what the battery health is, but good thing to consider nonetheless.
I don't see the battery indicator light as having anything to do with quality of the battery. I indicates the level of charge in the battery which has to vary if the dc motor is used.
2003 OG All Aluminum Hybrid Honda Insight Has been sitting for couple years. Have issues with it starting Sometimes. (IDK?) But when it does it seems to run fine around neighborhood streets. Comes...
1st gen MT in AZ.
Looks to be a diamond in the rough. Could make a great project for someone who can do a few repairs, replace the broken bits and maybe repaint it.
2002 Honda Hybrid, stick shift, the car has hybrid battery and gets 58 MPG, this car is super cool and economical specially with gas prices. The battery has a few bad cells causing the check engine...
2000 Honda Insight Base
$2,000
220,000 miles
Called and spoke with dealership today and it sounds like transmission is grinding a bit and ima battery is bad but runs.
